Results 1 to 4 of 4
Thread: bluesman2a : SOLVED: Strange brake problem...
    Atlanta, Ga.
    Default bluesman2a : SOLVED: Strange brake problem...
    Post by bluesman2a on Sept 11, 2006, 12:50am
    OK so I had me a ST-Range brake issue. My junk is parted together from several sources so it took me a while to track it down, but I nailed it shut tonight...
    So here's what I got:
    Corvette MC (great upgrade if you haven't done it).
    Brake pedal assembly from an automatic waggie.
    Stock push-rod.
    ALL new line/fittings (took FOR-ever to bleed).
    4 wheel disc brakes on CUCV axles.
    38.5" Swampers
    Problem:
    1) no matter how much I bled, still had spongy pedal.
    2) KNEW all the air was outta the system, no bubbles.
    3) Took Mico-Lock (parking brake holder) outta system to keep things simple.
    What I found:
    1) The waggy pedal assembly has to be slotted to line up with the MC properly. If you don't, the push rod will bind and not work right.
    2) Had shortened the stock push rod to deal with binding issue, but you gotta throw that out too, cause the hole is too big for the waggie pedal assembly's pin.
    3) The push rod was too short now, so made new one using 7/16 nut drilled smooth inside with a 3/8 bolt welded to it.
    Now here's the biggie!!!!
    4) In the stock application the waggie assembly bolts to the bottom of the dash AND the firewall. That won't work with our dash so only bolted to firewall as interim solution. Noticed that the entire assembly was flexing when pedal was pushed. Thought it was odd based on how beefy the assembly is (bent/formed channel). So rigged up two rods (stock uses one on inboard side) to support the rear. OH MY GOODNESS!!! Between this and the slightly longer push-rod, I got a GREAT pedal feel. I can now lock it up any time I want to!!!
    This was SO cool, I even treated my self to a trip outta the business park (sans hood) down to the gas station to fill up the tank for the first time since install!
    Default compexp :
    Re: SOLVED: Strange brake problem...
    Post by compexp on Sept 11, 2006, 6:55am
    sweet! those little niggling problems are the worst to troubleshoot!
    Post by brute4c on Sept 11, 2006, 9:26am
    Good job...and nice of you to document it all for us!!
    Atlanta, Ga.
    Post by bluesman2a on Sept 11, 2006, 9:51am
    I'm not sure the planets will align in THIS particular configuration very often, but for those who do, hope it helps.
    I really like using a mixture of new and/or readily available/cheap parts to resolve issues. Authenticity isn't a big deal for me, but functionality and durability ARE, so I often come up with some "unique" problems.
    Everybody knows the way you solve "unique" problems is that YOU NEEK up on them from behind (it's a joke, say it out loud).
  1. bluesman2a : The bestest brake bleeding tool EVER.
    By bluesman2a in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 01:46 AM
  2. bluesman2a : IMPORTANT Brake Fitting info!!!
    Last Post: November 11th, 2009, 12:57 AM
  3. strange noise
    Last Post: October 1st, 2008, 11:17 AM
  4. Brake Problem
    By partmaster in forum Open Discussion
    Last Post: January 25th, 2008, 12:28 AM
  5. Brake Line Problem?
    By fisherman in forum Modified Tech
    Last Post: October 2nd, 2007, 10:13 AM
