Results 1 to 6 of 6
Thread: bluesman2a : IMPORTANT Brake Fitting info!!!
    Atlanta, Ga.
    Default bluesman2a : IMPORTANT Brake Fitting info!!!
    Post by bluesman2a on Apr 21, 2006, 12:10pm
    In replacing everything on my truck, I ran into a snag trying to get replacement brake fittings (specifically the block). Nobody had the 3 way 3/16 inverted flare WITH an 1/8" NPT for the brake pressure switch...
    Made an important find: HARLEY's have EXACTLY what we need and it's even relatively cheap.
    Check out http://www.dragspecialties.com/fatbook/1731/53/2374322
    Part # DS-097036 Rear T-junction with two side inverted flares, center inverted flare and bottom 1/8? NPT for 51-54 Servi-car; 58-69 FL, FLH (repl. OEM #83566-51)
    Default brute4c :
    Re: IMPORTANT Brake Fitting info!!!
    Post by brute4c on Apr 21, 2006, 1:01pm
    Excellent!!
    Thanks for the post!
    Northern Colorado
    Default fsjguy :
    Post by fsjguy on Apr 21, 2006, 3:41pm
    Try pulling into the Harley shop with your truck and tell em you "need some parts for the ol' girl!"
    Atlanta, Ga.
    Post by bluesman2a on Apr 21, 2006, 9:36pm
    Actually I went to pick this up at a local cycle shop, the parts guy asked me what it's going on... We had a good chuckle when I explained to him that the same fitting used on a 51 Harley with a side-car also fits a 67 Kaiser M-715...
    Default robertcowan :
    Post by robertcowan on Apr 21, 2006, 11:43pm
    Super good info. thanks for your efforts. this will help alot of guys i feel sure. i hope all zoners would only put forth such an effort ! bob in tn.
    Default barrman :
    Post by barrman on Apr 22, 2006, 5:16pm
    I stopped at a Harley shop on the way to the Texas FE last fall looking for some headset mic muffs. I was at the parts stand for a few minutes when one of the mechanics walked in and wispered in the parts counter guys ear. He excused himself for a few minutes and then came back with a big smile. He asked me if that was my "big white cool looking thing in the parking lot?" Colton got a kick out of all these biker guys looking all over it before we could leave.
    Now I have a reason to go to the Harley shop that actually makes sense.
  1. Brake shoe replacement info
    By adk4x4 in forum Stock Tech
    Last Post: February 3rd, 2019, 01:10 PM
  2. Emergency brake band bolt info
    By Duane in forum Stock Tech
    Last Post: February 24th, 2010, 07:35 PM
  3. bluesman2a : SOLVED: Strange brake problem...
    By bluesman2a in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 03:07 AM
  4. bluesman2a : The bestest brake bleeding tool EVER.
    Last Post: November 12th, 2009, 01:46 AM
  5. Brake T fitting....AGAIN!
    By fng in forum Modified Tech
    Last Post: May 13th, 2007, 10:03 AM
