Results 1 to 5 of 5
Thread: 1920 carb fuel bowl inlet baffle
    Default 1920 carb fuel bowl inlet baffle
    I recently dismantled my holley model 1920 carb (stock) for rebuild. Normally, there should be a baffle at the fuel inlet (inside the fuel bowl). Mine is gone, probably from a previous rebuild. Is this baffle a must for proper function?
    if the fuel sloshes around to much it might keep the float from shutting off the needle valve properly id say. i imagine you could cut one out of some thin metal w tin snips if you had a pattern or perhaps someone here has some parts carb they can sell it out of
    68 M-715 MVPA #2710
    It is a needed part...especially if you drive offroad.
    Many thanks.
    Yes I'm planning on using the truck 99% offroad so I'm thinking of fabricating one. I'll use a suitable plastic (PET, PC, PVDF PTFE or PES) depending on which I can find on my work bench...
    KINGSPORT, TN.
    i,ve got a parts carb probably if needed.
    bob
  1. binfordm715 : Now what do I do?! (Holley 1920 rebuild)
    Last Post: November 11th, 2009, 01:45 AM
  2. Holley 4bl Carb, AMC 360 - Carb rebuild time?
    By BubbaWilkins in forum Modified Tech
    Last Post: July 6th, 2009, 11:54 AM
  3. 1920 Holley Carb on the M715
    By Captain Jack in forum Stock Tech
    Last Post: January 24th, 2009, 05:27 PM
  4. possible Holley carb return fuel line
    By pavel3 in forum Stock Tech
    Last Post: July 20th, 2008, 05:53 PM
  5. 1920 Carb Replacement
    By generalcuz in forum Stock Tech
    Last Post: October 2nd, 2007, 11:29 PM
