Results 1 to 8 of 8
Thread: Th400 not shifting ??? Speed question at 3K RPM
    Oxford, Ohio 45056
    Default Th400 not shifting ??? Speed question at 3K RPM
    I drove the M715 down the road today. The 502 runs great. However, the TH400 doesnt seem to be shifting. It seems stuck in a gear. I hope its sticking in second, I no its not low gear. It aint going to go very fast if its stuck in high.
    IT is a new rebuilt tranny.
    Goes into reverse, Neutral, and drive just fine.
    Will NOT shift when starting in low and trying to shift up in gears.
    Vaccum at modulator valve is 15lbs.
    Fluid is new synthetic and full
    A few times it did shift down when I pulled shifter from 2nd. to low.
    1) Anyone have any suggestions?
    2) Also can someone tell me what speed you will be running at 3000 RPM ,46" tires in 3rd gear ?? I have seen a calculator somewhere.
    Chris
    You can use the spreadsheet I have linked below to play with:
    Tire diameter
    Gear ratio in trans
    Gear ratio in tcase
    Gear ratio in axle
    The rest will be figured for you.
    I can add columns if you like as well...just ask.
    Heres the link...right click...save:
    http://www.m715zone.com/jonmisc/RPM_Calc.xls
    I think your 3rd gear is 1:1...so that and 46 inch tires with stock 5.87 axles gears is 69.9 mph...not accounting for the 5-7% slippage of a non lockup converter...66.4 mph taking the slippage into account.
    Mar 2004
    northern Arizona
    Well, by your chart, at 60 mph with my proposed setup, i'll be turning 1600 rpm - much better than the 3000 I do now.
    67 M725 67 M715 68 M715
    Sounds like the govenor might be stuck. Pull the 4 bolt cover off the right side of the trans, pull the govenor out. The valves should move up and down inside it as you squeeze the weights on the side. Hard to explain, but if you have a problem, have your local trans shop take a look at it for you.
    Northern Colorado
    If you vac modulator is installed with the elbow fitting, make sure you have the linkage that goes INSIDE the elbow. The tranny will not like it if that part is missing. It will eventually stop working and puke fluid out the the fill hole and leave you stranded on the side of the road in the dark.
    NorthEast Texas
    You could also have a governor gear stripped.
    Oxford, Ohio 45056
    I pulled the governor, it looks and seems to work fine. I am taking to the tranny shop Sat.
    Thanks for your help.
  1. NP205 shifting
    Last Post: July 18th, 2009, 03:35 PM
  2. Shifting the 4 Wheel Drive
    By dasparkgun in forum Open Discussion
    Last Post: August 17th, 2008, 02:49 PM
  3. Shifting data plate
    By gonz in forum Modified Tech
    Last Post: May 5th, 2008, 11:36 PM
  4. Stock Trany Shifting Questions
    By joesco715 in forum Stock Tech
    Last Post: November 30th, 2007, 10:01 PM
  5. Rules for Shifting?!?
    Last Post: November 18th, 2007, 11:51 AM
