3 Lever Headlight Modernization/Aux Use
Guys,
Thinking about using an original 3 lever military switch to retain some authenticity even though im axle swapped and diesel swapped.
While I'm not quite sure if this is possible... I'd like to have the 3 lever function as.
Lock-Unlock lever remains its function (power to switch)
Off to Stop Light functions as a normal headlight switched pulled out half way (running/turn lights operational)...
Service Drive would be runnign and headlights (normal headlight switch pulled out all the way).
The blackout light side of the switch would never be utilized.
The Panel lever I'd like to utilize as following.
Panel Panel Dim and/or Bright would both throw power to what I'm planning as 2 or 3 courtesy lights mounted under the dash to light up the footwells as night for entrance.
The panel lever in the park position would throw exterior floods (additional reverse lighting).
Can you seperate the 3 levers to control individual pinouts?
