I am converting an early truck with the big non solid state turn signal box to 12 volts. I want to use as much of the stock wiring and switches as possible (adding fuses, of course). It is a SBC conversion with a 700R4 and the owner wants 12 volts.
I have been doing some reading up on this and if I understand correctly, the solid state turn signal box will function fine on 12 volts. Is this the case?
I saw mentioned that there is a conversion harness and the solid state box available.
My question is what are the part numbers for the solid state box and the necessary harness to adapt it to the older style wiring? I want to make sure I'm getting the correct parts.
I have the older style spartan turn signal unit as well, so I will need to upgrade it, too.
What is the most commonly available switch that will work? (stock column)
Where is a good place to get it all?
Is there anything else specific about this conversion that I should be aware of?
Thanks,
Greg
MBs and GPWs
No 715 now, but 20 years ago...
