Hello,
Could somebody provide me with a sketch of the ventilation system connecting the vacuum pump, air cleaner, ignitor and transmission parts (small rubber hoses) on Tornado engine.
Thank you in advance,
Phil
Hello,
Phil
From the Zone's on-line manuals from above:
Vent Line Diagrams
John has also done the following Vent Diagrams for the early & late style setups:
early style aircleaner: http://www.m715zone.com/vb/view.php?pg=early_vent
late style aircleaner: http://www.m715zone.com/vb/view.php?pg=late_vent
Thanks !
What's the difference between early air cleaner and late style ?
Sorry, I found the differents air cleaners types...
I have the late type with 2 pipes : one hose which comes from fuel tank vent and the other ? (there is a small and a larger pipe)
Where is connected the hose which comes from the valve located in the intake manifold, under the carburator ?
Sorry for my bad english !!
Phil
"Where is the hose connected which comes from the valve located in the intake manifold, under the carburetor?
Looking in the online manuals: http://www.m715zone.com/vb/view.php?pg=20chap2-11
If you have a governor mounted under the carburetor, Figure 2-18 shows this as hose #9.
I don't know the answer since I don't have this type of aircleaner. Hopefully someone on the Zone will help answer this.
If you don't have a governor, then you are talking about the hose #2 in Figure 2-17 which connects the PCV valve to the valve cover.
I may have found what you are asking about.
Download
"Installation Instructions for the Governor and Desert Aircleaner, large canister type."
http://www.m715zone.com/vb/pages/man...aircleaner.pdf
The governor vent line is connected to the aircleaner horn.
See page 15, figure #6. governor vent hose #8
also see page 10, figure #1
Thank you very much, that's what I need !
Phil
