Results 1 to 10 of 17
Thread: 15" rims
    Oct 2009
    charlottesville VA
    Default 15" rims
    hey
    i was just wondering im about to have a set of 44" swampers and was planning on having marsh racing make me some rims... but the tires are for a 15" rim... can you fit a 15" rim on the front axle or will it rub or can a grind the calipers some?.... anyone?
    thanks
    There are no calipers on the front of a stock M715.
    Oct 2009
    charlottesville VA
    lol good point will a 15" rim fit over the drum sorry
    Oct 2009
    charlottesville VA
    eh.....nobody knows???? guess i got some figuring out to do
    Sorry, I guess no one was paying attention. I think they work, but not having done it myself I wouldn't swear to it.
    भगवान तुम्हें प्यार करता है
    People have used 15 inch rims on the stock axles with the stock drums...though I dont know the exact backspacing they used...heres 2 pics of a truck with the 15's over stock drums:
    those rims look so tiny!!
    The tires the wear are 39.5's...
    Default 15 in rims
    i meassured the drums to see if i could get 15 in rims on mine and i came of with 4 1/2 backspacing would work any more and it wouldnt fit over the back last 1/2 inch of the drum . the rim will fit up to that last 1/2 inch but you should check this out for yourself to be sure .
    Mine had 13" wide x15's with 4.5" backspacing. Fit fine with 44" Mudders.
    Rode and steered very smooth on the road with balanced tires.
    I agree what Randall says. You might get a 5" backspace to work but it would be very tight on the front brake drum ridge. The rear drums are inset so far, just about any backspacing would work there.
  1. 8 lug 20" rims
    Last Post: May 15th, 2011, 10:39 AM
  2. Mike's Restoration Thread, "The List", Current Progress...
    By BubbaWilkins in forum Open Discussion
    Last Post: January 27th, 2011, 03:24 PM
  3. Tires for 20" rims
    By g8trwood in forum Open Discussion
    Last Post: March 25th, 2007, 08:21 PM
  4. big street tires?changed to i need CHEAP 20" rims
    By Nuke_mcinfantry in forum Open Discussion Archives
    Last Post: May 18th, 2004, 11:42 PM
