Results 1 to 4 of 4
Thread: Cracked exhaust manifold, etc.
    Default Cracked exhaust manifold, etc.
    I'm going to look at a stock truck for sale with a cracked exhaust manifold. Are replacement manifolds hard to find? Would it hurt the 230 engine to drive it with the bad manifold? Should I be looking for the cause of the crack or is this common on these engines?
    Are replacement rocker panels available?
    Is there anything in particular I should check closely? Supposedly everything is original and works.
    I put one I had on E BAY hate to sell but its not doing me any good sitting in that box
    The manifolds do like to crack. If one has a good welder around and does the right prep and followup, they can be welded succesfully. Check this thread:
    http://m715zone.com/vb/showthread.php?t=9457
    It has great info about welding.
    If you have an uncracked manifold, this is the ticket to preventing future craacks:
    http://m715zone.com/vb/showthread.php?t=8881
    Thanks for the info Brute
  1. Exhaust manifold gasket part #
    By scuba_dew in forum Stock Tech
    Last Post: July 7th, 2009, 02:14 AM
  2. How to prevent a cracked exhaust manifold
    By brute4c in forum Stock Tech
    Last Post: February 22nd, 2009, 11:37 PM
  3. Dorman exhaust manifold
    Last Post: June 12th, 2008, 09:49 AM
  4. Cracked manifold fix?
    By vacca rabite in forum Stock Tech
    Last Post: May 26th, 2008, 08:40 PM
  5. Exhaust manifold replacement ??
    By viperman in forum Open Discussion
    Last Post: April 17th, 2008, 02:26 AM
