Well I went out to start the 715 today it started fine but then would die when I tried pulling out. I can hear the fuel pump running but the filters have very little fuel in them. I pulled the aircleaner and cleaned the carb out real good and then I saw fuel leaking from the rear of the carb. It was leaking from the throttle lever (part #49 in the 34 manual). It was like a slow drip when I would depress the throttle lever a few times manually. I'm going to assume that this is a sealed part and there is no way fuel can leak out of the shaft, please correct me if I'm wrong. So I'm thinking maybe the the carb to intake gasket is bad.
Now to my question I did a search and read up on the carb rebuild kits out there. Did anyone try the suy from Canada? Are the AB Linn,Memphis kits ok with modern fuels? I love driving this truck but it has been such a PITA compared to my CJ8.
