Does anybody have a good tune-up checklist for a new M715? It would include all the standard stuff plus any M715-specifics. Here's what I'm thinking:
Ignition system - points, condenser, coil, distributor cap/rotor, plugs, wires
Fuel/carb system - fuel filters, air filter, carb cleaner, etc.
Lubrication/cooling - change differentials, transfer case, transmission, engine oil, coolant, check for leaks and replace seals/gaskets
Tires - check pressure
Brakes - bleed and fill brake system, check for leaks
Is there a good list in any of the TM's? Thanks!!!
