Is it possible to bench test a fuel pump? I have a used one, it came from a motor that had been sitting. It is certainly the correct one for a 715. It feels like the input shaft is pretty stiff. In fact, it really only moves a little bit. Should the pump be able to be manually tested? How much force should this take? (by Hand
?) I am probably going to rebuild this, with a kit from then-now.com, as I have found on a search. I was just curious for the time being if there was a good way to find out if anything was seized up inside.
