Results 1 to 9 of 9
Thread: Tow Bar Adaptor Measurements
    Default Tow Bar Adaptor Measurements
    I let the last set I saw on E-Bay go without even bidding for $76.00. ( thought about 20 of you were waiting to snipe it at $150 or so and figured to just watch.) That was months ago and I haven't seen any since. So, I am going to build a set.
    I have metal the correct thickness to go into my tow bar feet and I have metal the same thickness as the shackle hooks. I have pictures of the adaptors and can figure out pretty close what size they should be. But, I don't know exactly.
    It looks like 3"x3" on each leg going into the bumper, 3" between the two thru bumper legs, 3"x3" on the part that the shackle hook can be moved to and then from measuring my M35 tow bar/shackle mounts I think 2"x2" on the round front part to be about right.
    Can anybody with a set measure them and tell me if I am waaaay off?
    I will...good thinking to make your own and to get the measurments on the site...they will only get harder to find.
    Give Raymond and I a few and we will have it for you.
    Jan 2007
    North West Arkansas
    Default Photos
    If you need some photos I just had someone give me a set, let me know if need the photos.
    James G.
    Ok...sorry for the wait, had to make supper and all...hope this is everything but if I missed a dimension, just let me know.
    This is a top view, left is the truck end, with dimension markers:
    A: Overall length 9.5 inches
    B:Towbar end to start of curve 2.995 inches
    C:Towbar end to end of curve 3.235 inches
    D: Length of center section 2.765 inches
    E: Length of truck end 3.550 inches outside and 2.960 inches inside
    F: Width of towbar end 1.495 inches
    G: Center section width 2.667 inches
    H: Gap in center section 1.100 inches
    I: Center section wall thickness .800 inch
    J: Width of opening, truck end 2.905 inches
    K: Thickness of truck ends .700 inch
    L: Thickness of wall between center section and truck end .578
    Here is a side view, left is the truck end:
    A: Height of adapter 2.995 inches
    B: Smaller holes, truck end and center .75 inch
    C: Large hole, towbar end 1 inch
    Like I said, need anything else, just ask.
    Perfect, Thanks Jon.
    Glad it helps!
    This came up in a wanted add today. Instead of messing up the add thread, I brought this one back from the dead. I ended up getting a set of real feet instead of building my own. The main reason being liability.
    If a manufactured, non modified part breaks when I am using it in the prescribed manner. That is totally different than an experimental home built critical link to connecting two vehicles together.
    Just my opinion.
    However, I also added a set of M35 rear shackle hook mounts to the top of my M715 before I bought the proper M715 adaptor feet. So, I can use the tow bar either way. I like the M715 feet best because they make a great step while working under the hood.
    Here is the thread about the M35 mounts:
    My Tow Bar Mount Solution
    I saw someone asked...I didnt have time to look for the info....I am so glad you did Tim...THANKS!!
    Very nice idea guys.
    If you might need my help I am glad to help :
    I work for the largest Greek casting company and I can make a lot of cast parts for just the cost of the material.
    Jim
  1. I need two measurements!
    Last Post: September 1st, 2009, 11:57 AM
  2. 24V-12V adaptor
    By phoenix in forum Open Discussion
    Last Post: December 27th, 2008, 12:32 PM
  3. stock measurements
    By 90volts in forum Stock Tech
    Last Post: January 5th, 2008, 06:10 PM
  4. in need of measurements
    Last Post: November 12th, 2007, 02:16 PM
