The truck is back on her feet and today I rolled her out for some testing and to reverse it in the shop. Wiring finished and tested and new plumbing under the hood. The truck had no thermostat in it from the PO so we put a new one in there. Now it overheats. No water flow to the radiator. Radiator and hoses are cool while the temp gage is pegged. Can it be a new thermostat that is defective or since the system was drained can it be air bound? The thermostat housing seems hot but it isn't opening. What temperature thermostat should be in here? I put a 180 in but we ran hotter then that!!
