Originally Posted by
sermis
I have a M725, ambulance version of the M715. I replaced the motor, which was bad, with a SBC 350, power steering, duel brake master with booster, and 11.00 / 16 XML’s. It would be a daily driver except for the 6.5 mpg’s. It will go anywhere except through the trees. I have put somewhere between 7,000 to 8,000 miles on it. Love it but gas is a killer. With the stock motor don’t expect to go much over 50 mph for long with out something in the motor coming apart. I must have a good T-case as I don’t seam to have heat issue or noise that some have but I did swap the drive shaft to the center.
Thinking of the 3053A to have overdrive, 205 to have speed with out heat issues, and CUCV’s to have higher gears to help on mileage.
Now I have found a M715 project truck, it all starts over, and over, and over.
It is a green iron sickness……………………………I want more trucks……..
