Results 1 to 9 of 9
Thread: Limited slip diff
    Default Limited slip diff
    Someone makes, or made a limited slip diff that uses gears to limit the slip instead of clutch packs. I am at a loss right now. Anyone know the name to help me out?
    Gleason Thorsen? Excess worm gear wear issues if I remember right. Who else?
    I'm a dana dude so all that other stuff is still new to me.
    Liz, covid, murdered 10/19/21
    Thorsen kinda rings a bell, I'll see what a search comes up with. Thanks.
    Yup, this is what I was looking for, Thanks again Al.
    http://www.houseofthud.com/Torsen-in...les/Torsen.htm
    Jan 2007
    Georgetown, CA
    The Auburn Tru-Trac is the same basic design, uses loading of spiral gears to limit slippage. I have one in my Land Rover, . .works excellent, ..open diff on the road, locks up when loaded, . . A really nice setup for a rig that spends most of its time on pavement. I don't know if they are available for stock M715 axles, but later stuff they are.
    Huntingtown,Md.
    I would think the 'Tru-trac' is stronger, if it's available.
    Default limited-slip
    I have a " DETROIT LOCKER " on the rear of my 715. it is not air supplied like you see on some current new truck's. By the way, am new to the board so HELLO to all ! TOM
    Auburn, AL
    Welcome to the Zone, Tom!
    Default limited slip
    Snuffy , thanks for the greeting, I did not mean to inject myself too deeply into this topic, but with the Detroit Locker in the rear , and a Power Lock up front with WARN locking hubs, I can tell you that as long as that I have some solid footing under the wheels/tires this truck will literally go anywhere . NOT bragging, just with the Granny Low 1st gear & LOW Range in the transfer case with the 5.87 gears it is just about unstoppable. Semper Fi ! tom
  1. Do I need a Slip jont from Trans to T-case?
    By Craig Merrill in forum Modified Tech
    Last Post: April 18th, 2008, 03:12 PM
  2. power-loc limited slip differentials?
    By m725kid19 in forum Open Discussion
    Last Post: July 14th, 2007, 12:36 AM
  3. Limited Slip
    By CaptainMorgan in forum Stock Tech Archives
    Last Post: May 9th, 2004, 01:50 PM
