Results 1 to 10 of 13
Thread: Bellhousing Plug
    Dec 2007
    Jim Thorpe PA
    Default Bellhousing Plug
    Looking under my truck, I saw a threaded hole in the bellhousing. I did a search and looked through the manuals and found out (I think) it is a water fording plug. My (maybe dumb) question is: does the plug belong installed at all times, and take it out to drain water after fording, or leave it out, then install it before fording? I would guess it stays in. Also, I saw in the search that it is a pipe plug (The bellhousing fordng plug is a pipe plug...square head. -brute4C, May 18th, 2007, 02:26 PM)-- does that mean it's just a regular hardware store NPT fitting?
    It is intended to be installed prior to fording an removed after, many truck got a stencil or decal on the dash w/ that instruction. I keep mine in the glove box, it is standard thread, however it isnt a typical pipe plug it is flanged.
    68 M-715 MVPA #2710
    Dec 2007
    Jim Thorpe PA
    Thanks! So, in normal circumstances, the drain is just open to the environment? I'll have to look around inside and see if the plug was stashed away somewhere.
    That is correct...in to ford...out the rest of the time. The bellhousing vents the oil from the leaky rear main seal on the 230, among other reasons for it being there...in the fording application, the fording valve pressurizes the axles, gearboxes and master cylinder. With the plug out, the pressurization wouldnt work and would leak out this hole. With it in, one will notice the boot on the shifter will actually inflate, thus telling you the fording system is operating as designed.
    The reason for the pressure is that when one is going through water there is pressure from inside the axle or gearbox going outward, so if there is a leak it will be from the inside out pushing water away, instead of driving in water and possibly having it leak in to those components.
    If you dont have the fording kit with he fording valve to pressurize the stuff, it still keeps water and mud and etc off the clutch...a good thing to protect.
    Anybody have a detailed picture of one? I made one but the handle or wings are not right I'm sure.
    Liz, covid, murdered 10/19/21
    And don't forget to switch the valve in the gas cap too.....
    If yours has it....some dont..like mine.
    Heres an image from Saturn Surplus of the M151 cdrain plug for the bellhousing...M715 is similiar...
    Pipe plug with a flange on the head.
    Really? I wasn't aware of that. What did they do in that situation then?
    Mine is the non vented variety. The fording caps are vented and non vented by the position of the lever...so mine is like the fording one locked in the fording position...the gas tank would be pressurized through the vent line just like the fording one.
    When I first got my truck and drove it a distance, it died and wouldnt start...checked a bunch of stuff, then realized there was no fuel to the carb...took off the gas cap and it sucked in deeply...got home and checked the vent line from the filler neck to the air cleaner...where it gets low between the tank and the air cleaner, it was full of gas...blew out a ton with the compressor...probably had been overfilled enough times over the years and it settled in the low part of the hose blocking off the venting of the tank.
  1. Bellhousing Q?
    By pghjeeper in forum Stock Tech
    Last Post: May 28th, 2008, 11:30 PM
  2. What bellhousing?
    By Grantshire in forum Modified Tech
    Last Post: February 22nd, 2008, 04:11 PM
  3. Bellhousing question
    By pistolnut in forum Modified Tech
    Last Post: February 4th, 2007, 10:46 AM
  4. Diesel bellhousing patterns
    By svobronco in forum Open Discussion Archives
    Last Post: March 3rd, 2004, 08:38 AM
  5. Ford Bellhousing?
    By Hetzer in forum Modified Tech Archives
    Last Post: January 19th, 2004, 07:22 PM
