Does any one know where or how to get replacement belt for generator. Is there a truck replacement I can use or do I need to find a M715 replacement. Thanks.Bill
I moved this post to the stock tech forum.
If you look at the top of this page, you will see a link called "manuals." Click on it and find the parts index list a page or so down. You should find a cross referrence to current part numbers there.
I dont know a number offhand...mght b on the temp site...I'll check quick...
If you cant find a belt for anything...or dont know what it takes, measure the width of the pulley groove and put a tape around the pulleys involved...or use a string and measure the length needed on a tape...and go to a decent parts store...they will know how to convert that info...the way belt numbers work, it includes the V groove width and the length in the numbers.
Well...its not on the temp site...wait...found this info on this board:
From ChalkOutine on what info is on the Napa belts he bought:
That # is 7417
other letters and #'s on the package....
XL
Belt/Courroie/Correa
25
7417
Another member, jdobyns, posted:
I found that NAPA number 7425 work pretty well....and are not as tight to get on.
And another member, adk4x4 said about that:
I got the same ones and they work perfect for me. The alt is about mid way on the adjustment bar. They were napa deluxe xl's 7425.
