First I replaced the valve cover gasket..that took a lot of it away..
Then while i was checking the fluids in the tranny tcase and diffs, I discovered that there are 5 bolts missing from the oil pan!!!
Theres my other leak..I cant believe im missing that many. OH well..
Can you use silicone or do you need to use a gasket for the oil pan?
