I'm challenged with trying to test and see if I can determine if my alternator is charging my battery. I've read through the forum a coupleof times and my alternator doesn't seem to match the 'stock' description. I'm starting to think that I may have a aftermarket alternator that would have been replaced by the Fire department that owned the rig before I did. It's kind of hard to see the plate on the back of the alternator but I'm pretty certain it made by Prestolite. I can clearly see that the specs are 24V 42 Amp. I have tested the output and with the battery's disconected I'm only getting 24.6 volts. The charging gage never gets out of the yellow zone, so I know from reading the forum that I'm not really getting the recommended 28V charge while the engine is running. Anyone have any info on this particualr alternator? I'm going to geta picture of the alternator on the forum this weekend and hopefuly squint at the name plate, backwards with my inspection mirror to get the full model number of the unit. I do have an aftermarket battery charger hoked up to kep the battteries at full charge in between starts and running. My concern is if I'm out for the day and it won't fire up. I did experience a 'dead' battery a couple of weeks ago and that was the catalyst for checking the charging system.
