Results 1 to 1 of 1
Thread: Bcowanwheels
    Default Bcowanwheels
    BCOWANWHEELS,
    Numerous times we have tried to explain the rules of the site to you only to have you continually bypass them. We are not here to babysit people, we are here to provide a first class information source for the M715 and it's variants. When someone continually distracts members and staff from that task we are forced to take action. The total volume of our time that has been wasted on these simple issues is staggering. We have tried to be accommodating and work through these issues with you numerous times only to see them continue on. You have skated on the edge for years. Enough is enough.
    Please note that we do acknowledge that at times you have been helpful to members, and most who have met you in person feel you come across much differently in your text here than you do face to face. Unfortunately the good is not enough to offset the negative impact left by allowing your bad habits set an example for others to follow.
    You are being suspended for a period of 30 days.
    Reason: Repeatedly advertising parts/services in tech boards after several request to keep your business in the classified section where it belongs. When someone fails to agree with you, you use negative and insulting comments which are many times pointed at the majority of our members. This is not acceptable.
    Please note that your user name is being temporarily banned, if you attempt to find a way around that such as logging in under an alternate account, you will be permanently banned. When your suspension is up, Keep in mind that this suspension was your last warning prior to banned permanently. It is highly suggested that prior to your return (if you choose to do so), you read the rules throughly and abide by them. In or out, it is up to you and your actions from here on...as it always has been.
    Sincerely,
    M715 Zone Management.
    Last edited by brute4c; November 1st, 2007 at 11:54 PM. Reason: Changed members name
