Results 1 to 10 of 12
Thread: Granny gear crazy noise!
    Default Granny gear crazy noise!
    I forgot to mention when i went to look at the truck, We took off in granny gear, It was making all sorts of loud grinding noises, he said its always done that. But 2nd was quiet. Do ya'll granny gear make that much racket??
    Springdale, Arkansas
    Sounds like something may be wrong. Mine didn't make any noise except when I forgot to double clutch. It's pretty easy to pull up the floor and cover just to look around, but don't use an aluminum flashlight and accidently drop it down into the tranny...don't ask me how I know about that one...
    New Jersey by Philadelphia
    Grinding noises aren't good period....
    Lone Pine, CA
    1st gear will have a distinct sound to it. The several T-98s and the T-18 that I'm familiar with have it. I wouldn't call it grinding necessarily but more of a low whine with a bit of a grind to it. How's that?
    Chris
    OH no...first problem looks like. The noise..is, well, quite loud..Kinda like throwing steel balls on a tin roof.. Was told its always done that..either way.. I cant do anything till i get it home..was just wondering if yours do the same thing.
    Lone Pine, CA
    Ok, steel balls on a tin roof sounds like a bad noise
    Quote Originally Posted by SouthernM715 View Post
    Doesn't sound good....in low, you should hear a sort of gear noise, like a whine, growl, maybe, but no steel balls on tin roof!
    Sounds like a really bad bearing, or perhaps a chipped tooth. Pull the floor and trans top cover and see what you can see.
    KINGSPORT, TN.
    just drain the lube. it will tell the story. they probably hurt it cauz 1 st gear isnt syncro, you have to come to a stop to put it in that gear correctly, they probably didnt and hurt the trans. but i,am only a mechanic and just guessing
    Jan 2007
    Fort Smith, Arkansas
    So many people swap the motor and tranny together, you should be able to pick up a whole tranny for a lotcheaper than fixing whatever damage you find.
    You mean start in 2nd?
  1. Crazy Valve lash!
    By Maingear in forum Stock Tech
    Last Post: November 9th, 2009, 02:50 PM
  2. Third Gear Noise
    By Pineyguy in forum Open Discussion
    Last Post: March 8th, 2009, 08:24 PM
  3. NDT tires w/tubless rims ? crazy???
    By saxon in forum Open Discussion
    Last Post: July 5th, 2008, 03:11 PM
  4. This is driving me crazy. Craigslist $1,500
    By amphi in forum Open Discussion
    Last Post: December 25th, 2007, 02:26 PM
