Results 1 to 10 of 12
Thread: Rear wheel inner seal...cross reference #
    Default Rear wheel inner seal...cross reference #
    It appears the cross reference link in the manual section is not working.
    I need 2 Fed # 5330-864-5774
    Ref # 11640818
    It is located in illustration #77 and labeled as #29 in that picture.
    Thanks,
    Jeff
    HELP!!! My wheels are ready and my tires come in on Wednesday!!! I want to get the leak fixed BEFORE I put it all back together!!!!
    Barrman, Brute, Binford, FNG, kwai.... someone knows.
    Thanks Guys (in advance)
    Jeff
    Lone Pine, CA
    The old seal will have a number on it. Take this number to a decent parts store and they will find the correct seal.
    The correct number is on this site several times over but I gotta get out before I can search and my notepad with parts numbers went missing somehow. I'm sure someone will wander by with the number though.
    Chris
    Here we go:
    Front axle: National 475384, Napa (dunno)
    Rear axle: National 476282, Napa 27600
    from Mozarkid
    YOU ARE THE MAN!!!!!!!!!!!
    I never lost the faith!!!
    Thanks, I am getting REALLY excited about going for my maiden voyage!!!
    Jeff
    No sweat...wish I had caught it earler.
    Springdale, Arkansas
    Boy am I glad you posted this thread!!! I pulled my right rear hub off and discovered everything was covered in a charred looking black greasy muck. The drum was literally dripping with gear oil. The shoes were s-o-a-k-e-d! So I pulled it all down to the part now where I need to take out the two nuts inside the hub. Was the size of the nut actually 2 1/2"? I measured as best I could with a tape measure but couldn't get a real good angle on the tape...
    Before I go on here are there anymore hidden tricks to dissasembly/reassembly?
    i would recomend reviewing the procedure in the manual especially for the specs and procedure for tigthening the nuts back. if you look inside the back of the seal lip there is a garter spring which keeps the seal tight on the shaft. when installing such a seal as you hit the seal with a tool the shock can sometimes pop that spring off and you may not see that an then have a leak still. so to prevent it coming off i place a dab of grease in about 3 spots in the back of the seal cavity there to keep the spring put.
    68 M-715 MVPA #2710
    The hub nuts are 2 9/16".
    Quote Originally Posted by kwai View Post
    I used the 2 1/2" hub socket, but it seemed a little too large, I suspect it is actually 2 1/4" - 2 7/16" at the largest, but I used the 2 1/2" and sloppy as it was, it worked.
    George,
    The grease on the back is a good tip!!
    Good luck FNG,
    Jeff
  1. Cross reference list for parts?
    By viperman in forum Open Discussion
    Last Post: September 26th, 2011, 06:30 PM
  2. rear trans seal
    By Duane in forum Stock Tech
    Last Post: September 24th, 2008, 09:17 PM
  3. Rear Main Seal
    By rboltz in forum Stock Tech
    Last Post: March 25th, 2008, 08:48 PM
  4. Moving/Re attaching rear arched Cross member
    By alosix in forum Modified Tech
    Last Post: May 7th, 2007, 09:04 PM
