Results 1 to 10 of 15
Thread: battery set up?
    Default battery set up?
    I'm sure you get this question all the time but does anyone have a picture of how they have their batteries set up on a 24V system? I had mine right but I cant remember how the cables went on since I got my new batteries. I put it back how i thought it went and ended up with sparks everywhere.
    67 M725
    St. Louis, Mo.
    Positive to the starter on battery 1. neg to the frame or ground on battery two. jumper cable connects the + and - of the two batterys. Its that simple.
    Been there. Make sure you don't have the ignition switch turned on and that the starter switch is not sticking in the engaged position. Trace the cables to make sure you know which is positive and which is negative. The negative goes to the frame under the cab.
    Maybe this helps...2nd diagram on the linked page called Primary Battery Feed:
    http://www.m715zone.com/vb/view.php?pg=early_harness
    is it possible to run a single 24v battery?
    Sure...as long as you get one big enough, that would work.
    Port Orchard, Wash.
    Check the CCAs on it....
    -- Tim Taylor
    The army had one for gen sets that was the same size as the 2HN but 24 Volts. I used one in a pinch many a time. I forget the numbers on it. 6HN maybe??
    Zone holster maker
    Optima Marine looks like a possible:
    http://www.apexbattery.com/optima-tr...batteries.html
    Tat the only one I see at a quick check of Google that has enough juice....
    how many cold amps are needed?
  1. battery box
    By ryanroo in forum Stock Tech
    Last Post: July 30th, 2009, 12:00 PM
  2. battery box
    By johnny rezny in forum Open Discussion
    Last Post: March 17th, 2008, 09:36 PM
  3. 725 battery help
    By pzkpfwbob in forum Stock Tech
    Last Post: October 13th, 2007, 01:00 AM
  4. Battery Box Lid
    By krek in forum Stock Tech
    Last Post: June 15th, 2007, 09:48 PM
