  #11
Old January 4th, 2008, 08:22 PM
ncjeepers ncjeepers is offline
New Recruit
ncjeepers is a Soldier
Wow. Was anybody else confused by the above replies?
I just pulled the hubs from a customer's M715 and here are the orig part #'s. The bearings AND seals were the same for front and rear, contrary to the parts manual and to some of the above posts.
Inner wheel bearing:
387A Cone/Roller (Timken)
382A Cup (Timken)
Outer wheel bearing:
18790 Cone/Roller (Timken)
18720 Cup (Timken)
Wheel seal:
475384X54 (National)
A set of bearings and seals should run around $60 per wheel. Don't buy them at your local parts store. They'll charge you at least twice the going rate. Find a bearing distributor or order from an online warehouse.
Tony Casey
BULLGEARInc.com
  #12
Old January 4th, 2008, 09:04 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Great info...direct and to the point.
  #13
Old January 5th, 2008, 08:02 AM
New Recruit
A great big WHOOPS!!! I wish I could edit my previous post to save myself some embarrassment. Seems I stayed in the shop too late last night and had my parts piles mixed up. The fronts and rears ARE different. Mods, please delete my previous post. Thanks.
Here are the orig part #'s for the wheel bearings and seals.
Front:
475384X54 Seal
Inner Bearing:
387A Cone/Roller
382A Cup
Outer Bearing:
18790 Cone/Roller
18720 Cup
Rear:
476282X54 Seal
Inner Bearing:
469 Cone/Roller
453X Cup
Outer Bearing:
368A Cone/Roller
362A Cup
Expect to pay around $60 for the front set and $75 for the rear set at a bearing distributor or online parts house. You'll pay at least twice that at your corner parts store. AB Linn will probably cut you an even better deal if he has them.
Tony Casey
BULLGEARInc.com
  #14
Old January 5th, 2008, 08:33 AM
New Recruit
All of the bearing #'s are still good.
The seals have apparently been superseded.
These should work...
Front Seal: p/n 475384
Rear Seal: p/n 416282
Tony Casey
BULLGEARInc.com
New NAPA part Numbers - Master Swap rboltz Modified Tech 11 September 13th, 2010 05:57 PM
rjenkins : Front and rear shock part numbers PseudoZone PseudoZone - Open Archive 5 November 10th, 2009 11:23 PM
rear wheel bearings terryb Stock Tech 2 March 6th, 2007 04:20 AM
NAPA brake part numbers Archiver Open Discussion Archives 0 December 24th, 2006 01:44 PM
NAPA brake part numbers Archiver Open Discussion Archives 0 November 3rd, 2006 07:11 PM
1998 - 2019
Copyright 1998-2019
