Results 1 to 3 of 3
Thread: stock brake pedal return spring
    Default stock brake pedal return spring
    Anyone got a good pic of their stock brake pedal return spring? My truck never came with one, and I just want to make sure I got the right replacement.
    I don't have a picture handy. But, there is a rectangle shaped cutout pretty much right above the brake padal foot pad with the pedal all the way toward the driver seat. If you put your head on the transmission tunnel and look at the brake pedal, you should be able to see it. You will need a light. The spring goes from there to the post on the pedal holding the mc push rod on.
    The -20 manual shows this pretty well too.
    http://www.m715zone.com/vb/view.php?pg=20chap2-24
    Port Orchard, Wash.
    I can take a picture if you need one. What...up under the dash is what you want? Just let me know if you need one.
    -- Tim Taylor
  1. NAPA part number for brake shoe return spring?
    By maddawg308 in forum Stock Tech
    Last Post: April 24th, 2021, 08:51 AM
  2. Brake Pedal Return Spring
    By countcv61 in forum Stock Tech
    Last Post: April 1st, 2010, 11:39 PM
  3. Brake Pedal Return Spring
    Last Post: April 1st, 2010, 02:32 PM
  4. Brake and clutch pedal brackets
    By Roger1952 in forum Stock Tech
    Last Post: January 29th, 2009, 09:43 AM
  5. Brake Pedal Position
    By gglithox in forum Stock Tech
    Last Post: September 2nd, 2008, 09:28 AM
