Results 1 to 4 of 4
Thread: front axle locker
    Default front axle locker
    I know that there is two pages in the manuals on installing lockers in the rear end. But what about the front end. I want to install a Detroit locker in the truck. But I want it in the front instead of the rear. What kind of locker do I need?
    I forgot to ask. What spline is in the front?
    Well, I can answer part of your question. Front axle is 30 spline.
    68 M-715
    67 M-725
    Now to answer the other part of your question, if you want to put a Detroit up front, then put a Detroit up front. Check out www.reiderracing.com, then click on "Differentials" on the menu to the left. Then go through the list and look at their applications chart. That is a pretty good list of available differentials (there are a few that aren't listed there), and it will also tell you if they make one that will fit a 30 spline D60. Does anyone see why those wouldn't work for the M-715's D60? Personally, I plan on running a modified Power Lock up front, so I haven't checked to far into front locker availability. Hope this helps.
    68 M-715
    67 M-725
  1. robertcowan : FRONT 8 LUG HUBS THAT FIT THE M715 FRONT AXLE
    Last Post: December 15th, 2009, 08:14 PM
  2. Front axle twist
    By CrashMorriss in forum Stock Tech
    Last Post: September 10th, 2009, 09:36 AM
  3. front axle lubrication
    Last Post: November 13th, 2008, 05:35 PM
  4. Locker question in the front?
    By fwdstuck in forum Modified Tech
    Last Post: November 19th, 2007, 10:08 PM
  5. m715 front axle
    By heepofajeep in forum Open Discussion Archives
    Last Post: May 24th, 2004, 10:29 AM
