Old May 11th, 2007, 07:22 AM
Elliott Elliott is offline
Elliott is a Soldier
Default M715 rims fit an M105 Trailer?
I know the specs for the M715 rims are:
Lugs are 5/8"x18TPI. The center hole is 5.5" diameter. Backspacing is 5.5". Width is 6.5 inches. Bolt pattern is 6 lug on 7.25"
Will these fit an M105 trailer? I know the trailer rims are 20", but will these bolt on ok?
What are the specs for the M105 rims?
Thanks guys,
Elliott
Edit, I see this was posted already in the general discussion column....
Old May 11th, 2007, 06:02 PM
BCOWANWHEELS BCOWANWHEELS is offline
Banned
BCOWANWHEELS BCOWANWHEELS BCOWANWHEELS BCOWANWHEELS BCOWANWHEELS BCOWANWHEELS BCOWANWHEELS BCOWANWHEELS BCOWANWHEELS BCOWANWHEELS BCOWANWHEELS
wont interchange.
bob
Old May 11th, 2007, 07:44 PM
k8icu's Avatar
k8icu k8icu is offline
Sergeant
k8icu is a Soldier
Are you looking at an M105 or an M101 trailer. The M101 trailers where 3/4 ton trailers made to go behind M37s, then M715 and then M880s, and then M1009s and even Hummers have pulled them. The M105 trailer is a 1.5 ton trailer and was made to be pulled by duce and a halfs M35 and larger vehicles. The M715 rims will not fit a M105 at all. The M715 rims will fit the M101 trailer with an addaptor to go from 5 lugs to the 715s 6 lugs. I'm just wondering if you have the right numbered trailer?
Zone holster maker
Old May 11th, 2007, 08:14 PM
Thanks guys, I was trying to get info for a guy and didn't know he'd already posted his question in the open discussion. He has the larger (105) trailer and the M715 rims won't work.
M101 and M105 hooked to M715 Pictures Barrman Open Discussion 18 November 11th, 2008 01:30 PM
M715 Rims Captain Jack Modified Tech 20 June 25th, 2008 06:54 PM
Stock Rims M715 vs. M37... rip68 Stock Tech 5 January 28th, 2008 08:59 PM
m 715 rims on a m105 trailer? colman Open Discussion 3 May 11th, 2007 09:16 AM
M105 trailer canvas corners porkchop Open Discussion 2 May 11th, 2007 04:00 AM
