Old May 5th, 2007, 04:50 AM
magnum04rt magnum04rt is offline
Civilian
magnum04rt is a Soldier
Question BJ's Off Road Alum Cross Flow Radiator
Does BJ's 1974-1991 FSJ Alum Crossflow Radiator fit into a 67 M715 radiator support?
If not , what modifications are necessary to make it fit / and - or does someone else offer an aluminum radiator that fits / performs is better?
I have a GM Engine to contend with as well.
Please advise,
Coop
Old May 5th, 2007, 05:02 AM
fng's Avatar
fng fng is offline
Sergeant
fng is a Soldier
Coop, don't know if this will help but here goes, For minimal modification to the Rad support I bought a 3 row unit for a chevy 396 BB and except for elongating a couple of holes for mounting, its pretty much a drop in. I'm using it to cool a 350 sbc and although it's not aluminum or crossflow, if it'll cool a 396-it'll cool an sbc.
If you're pretty good with fabing you can gently remove the passenger side rad support bracket and move it over a few inches to allow for a wider install. I don't know the exact dimensions it would provide but probably close to 2.5 inches gained latteraly.
Although I don't have any first hand experience with aluminum radiators several others have expressed concerns with the brittle nature of aluminum and it's lack of flex. I had originally considered aluminum myself until hearing their arguments about cracking one during offroading. Sounded reasonable to me...
Anyway, don't know if that really helps but maybe someone else will post up and give you more to go on. Tracy
Old May 5th, 2007, 06:20 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
To fit an FSJ radiator, you typically need to move the passenger side radiator support over...the truck has a narrow position, which the M715 uses stock, and a wider position, that some other applications use...have to cut part of the flat front wall out and weld the support back in after moving it.
You also need to cut out the top piece...the one in front of the top of the radiator...the factory chopped about 2 inches out of that piece so the radiator could sit forward into that area.
If you look at an FSJ in a junkyard, you can see thats what the actory did...and the cut on the top front panel is usually somewhat crude...looks like it was cut with an angle grinder and never smoothed out...
Cross reference list for parts? viperman Open Discussion 7 September 26th, 2011 03:30 PM
maddawg308 : Source for Red Cross markings (the BIG ones) PseudoZone PseudoZone - Open Archive 10 November 11th, 2009 09:35 PM
cross threaded brake fluid tee stranman Stock Tech 6 April 24th, 2007 05:41 PM
Alum Rad jeepcj Open Discussion 6 April 9th, 2007 08:15 PM
