Results 1 to 10 of 10
Thread: Pto
    Default Pto
    I would like to run a nv4500 tranny but my truck has the factory PTO and i would like to keep it functionable. Anyone running there PTO off of the motor? If so could you point me in the right direction for a set-up? Thanks guys...
    Not really sure what you mean by "running the PTO off the motor". They run off the transmission or t-case.
    **I heart Bump_r **
    You can buy a PTO that will fit the NV4500. Finding one that has forward and reverse like the stock one is going to cost some money though.
    Jan 2007
    way up north new york
    There are pto setup that run directly from the motor crankshaft.Allot of town type plow trucks run them ,so they can shift with out the binding problems from the pto drag.
    I have one that basically shaft driven from the front of the crank,With a cable disconnect. Also called a live PTO I believe.
    Does anyone have a part # or know of vehicles that had a NV4500 PTO set-up?? I would love to have more info on your PTO set-up no3shopset...
    Quote Originally Posted by gun512 View Post
    The last 4500 I bought came from a retired wrecker, with a PTO.
    Sounds like a plan BigWheelBob... That was for a rear mounted winch, correct?...
    yes it was.
    can you swith it to run up front? or does the PTO on the 4500 only hook up one way?
    Give this guy a call, he will know what you need for your application.
    http://www.ptohydraulics.com./
