Results 1 to 8 of 8
Thread: More knuckle cavity stuff
    Jan 2007
    Winona, MN.
    Default More knuckle cavity stuff
    After doing some additional research I found two "over the counter" products so far that seem like a good alternative to standard grease, high viscosity oil or home brewed knuckle pudding. I'm going with a Cononco product called EP Conolith. It's a low viscosity grease used for enclosed drivetrain components like log skidder knuckles. It's has the consistancy of like a thick milk shake. I also found a similar Mobil product called SHC007. They both sell for about $2.00/lb. Mobil also has a synthetic equivalent for about $7.00/lb. Problem is that the dealer only sells it in 5gal pails, but he did turn me on to one of his customers who sold me a gallon. We also use a Kluber product at work in one of our printing presses that is similar but that stuff was about $12.00/lb.
    Jan 2007
    Winona, MN.
    What I'm using is actually Conoco EP Conolityh 000
    For no more often than you change that stuff, it's good to pick a great product, but I'd go with the cheaper stuff too. The axle joints live in a somewhat protected enviroment and as long as there's some kind of lube in there the will live well. Far better chances of breaking one than ever having one wear out.
    Of course, submerge them in water repeatedly, and forget to clean them out and all that changes. I found the ugliest looking wheel bearing at FE 08 for that reason
    Remote, North Dakota
    FE 08? Does your M715 have the time machine option?
    Flux capacitor and everystuff!
    (06, oops!)
    Port Orchard, Wash.
    Oh, that was a wheel bearing?! I thought it was some dust that got in there somehow. Heh, heh, heh....
    -- Tim Taylor
    It was a wheel bearing from Mesozoic era
    Jan 2007
    Winona, MN.
    Yabba Dabba Dooo!!!
  1. Front Knuckle Seals
    By fng in forum Stock Tech
    Last Post: November 28th, 2007, 01:37 PM
  2. Knuckle cavities
    By terryb in forum Stock Tech
    Last Post: March 10th, 2007, 08:13 PM
