Results 1 to 5 of 5
Thread: Dodge 5.9 Magnum swap
    Jan 2007
    So. California
    Default Dodge 5.9 Magnum swap
    Has anyone dropped a Dodge 5.9 magnum engine in? I was given a 1996 2500 pickup and was thinking it might work to replace my stock engine with the magnum. maby put a nv4500 behind it an then a np205.Can it be done without major body fab?
    Yes, it's not a big deal, just weld in the mounts and go. I put a LA series 318 and just had to massage the firewall a little for valve cover clearance. I was trying to set the engine back as far as possible to get the shifter tower on the NP435 4 spd to line up with the hole in the trans tunnel and to get as much fan/radiator clearance as possible. If using a electric fan, and if you don't care much about modifying the shifter location and angle, up probably wouldn't have to get into the firewall at all. A tape measure is your friend.
    -What We Have, We Hold-
    A 1996 motor probably has EFI on it no? You will probably have to hook up the computer to make the thing run unless you plan on switching intake manifold so that you can run a carb if that is even possible. Otherwise like stated above it's just a matter of mesurring and alighnment.
    Zone holster maker
    My 1996 360 in the full size van is MPI....good power increase over the carb/throttle body versions from the past...
    There are dual and single plane carburator intakes for the Magnum series V8s from Mopar.
  1. Body Swap vs Drive Train Swap
    By ChalkOutline in forum Modified Tech
    Last Post: April 22nd, 2010, 07:55 AM
  2. uscgmatt : dodge 360 engine swap progress
    Last Post: November 11th, 2009, 05:04 AM
  3. one ton dodge d60 d70
    By noreallyicanfixit in forum Modified Tech
    Last Post: August 24th, 2009, 07:07 PM
  4. dodge coil spring front swap
    By pamuddyjeep in forum Modified Tech
    Last Post: July 22nd, 2008, 03:40 AM
  5. Put a dodge 318 into an M715???
    By Jeff in north Texas in forum Modified Tech
    Last Post: December 16th, 2007, 01:43 PM
