ForumsOnline Maintenance ManualsGalleriesThe M715 Zone Vin RegistryVintage Power Wagons Price ListLinks
Prev Previous Post   Next Post Next
Old March 16th, 2007, 06:31 AM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
Default 1-7/8"
That is the size wrench you will need to remove the nut that holds the pintle hook on the back of your truck.
Mine has never spun or moved without the help of a long pipe. Yesterday I told a student to remove it and clean it up. He did and after removing all the rust and adding grease, it spins just fine. It makes a nice step when turned sideways by the way.
1967 M715
1952 M35 W/W
1953 M35 W/W
1971 M35A2 W/W
1985 M1009
Mike's Restoration Thread, "The List", Current Progress... BubbaWilkins Open Discussion 20 February 2nd, 2009 08:15 PM
What color is your "Caution Max Speed" plate? AVL Jeeper Stock Tech 8 August 27th, 2008 07:39 PM
How much lift needed for 40"-46" tires under my M715? BrutusM715 Stock Tech 3 January 13th, 2008 08:59 AM
Brake hose and throttle cable "clips" rboltz Stock Tech 2 December 5th, 2007 05:35 PM
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1998 - 2010
This web site is subject to the protection of the copyright laws of the United States and other countries.
Except for Personal Use Only, you may not modify, copy, distribute, transmit, display, perform, reproduce,
publish, license, create derivative works from, transfer, or sell any information obtained from any part of the
M715 Zone website without the prior written permission of M715 Zone, LLC.
Written permission can only be obtained by contacting brute4c@m715zone.com
Copyright 1998-2009
