Old March 15th, 2007, 04:27 PM
dhood's Avatar
dhood dhood is offline
dhood is a Soldier
Default Parts Reference Mil. vs Civ.
Is there anyone out there who knows of a cross referrence for M715 military 230 Tornados with Civilian parts?
About the only major engine parts difference I see is in relation to the timing chain cover and all parts that are in that location (water pump, timing chain cover, oil pump, fuel pump, etc.). The head and block look the same, but how different are the military engines from civillians internally?
1969 M715 WO/W
Old March 15th, 2007, 06:46 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Actually...very.
The heads dont interchange as the front of the civvy head is narrower than the mil one...made up by the timing cover differences. The timing chains, rocker arms, cams and cam decks interchange. I am unsure whether the valves and seals interchange or not.
The cranks do not interchange as the mil one has a different pilot bearing hole diameter and different seal setups front and rear...the rods I am unsure...the pistons interchange though there are 7.5 and 8.5:1 compression flavors for civvy motors and mil ones are all 7.5:1. Oil pans do interchange as do the valve covers.
Intake, exhaust manifolds interchange as well as distributors, though the civvy one is 12 volt and has vacuum advance that the mil unit lacks. Civvy fuel pumps come with and without the vacuum pump...they do interchange with the mil one but if it doesnt have the vacuum part, you have to run the wipers another way. Civvy intakes come in 1 and 2 barrel varieties while mil ones are all the 1 barrel type.
Clutch, pressure plate, throwout bearing is the same.
Block, motor mounts, different.
Its a weird deal...2 relatively low production versions of the same engine with little in common.
Old March 15th, 2007, 07:00 PM
hiker's Avatar
hiker hiker is offline
Corporal
hiker is a Soldier
Oil pump works on both, just to add to the info.
Electrical Connector Reference rboltz Stock Tech 7 May 6th, 2019 11:25 AM
Cross reference list for parts? viperman Open Discussion 7 September 26th, 2011 03:30 PM
Great engine vehicle reference site 5quarter Open Discussion 0 June 6th, 2008 12:45 PM
Rear wheel inner seal...cross reference # ChalkOutline Stock Tech 11 October 22nd, 2007 08:55 PM
