Old March 14th, 2007, 07:35 AM
MarknessMonster's Avatar
MarknessMonster MarknessMonster is offline
Corporal
MarknessMonster is a Soldier
Default Rust removal ?
I pulled the truck out of storage over the weekend and found the floors with a good amount of light rust where the paint had been rubbed clean.
What are the best methods used to remove the rust and coat the surface to prevent further rust?
In the meantime, I sprayed the areas with oil and scrubbed a little with steel wool before putting the truck back in storage.
Thanks in advance for any and all replies.
Old March 14th, 2007, 10:53 AM
compexp's Avatar
compexp compexp is offline
Sergeant
compexp is a Soldier
Some guys have used POR-15, others have tried various other rust removal compounds.
I wire-brush my stuff, then use etch primer or the rustoleum rusty metal primer.
Old March 14th, 2007, 10:57 AM
IAN_M715 IAN_M715 is offline
IAN_M715 is a Soldier
i've used durabak coating for my floors. stuff is bullet proof.
ian
Formerly 1967 M715 #13889
Old March 14th, 2007, 11:19 AM
k8icu's Avatar
k8icu k8icu is offline
Sergeant
k8icu is a Soldier
If the rust is just surface then a wire brush, wire wheel or even a grinder (be careful not to grind to much) will remove the rust. Even Navel(sP?) jelly will remove surface rust.
Then a good primer and paint or POR-15 or similar product like listed above.
Zone holster maker
Old March 14th, 2007, 11:34 AM
gimpyrobb's Avatar
gimpyrobb gimpyrobb is offline
Sergeant
gimpyrobb is a Soldier
I agree with Rich, Rustoleum rusty metal primer works great. I just got some cans of rust converter that I need to try, will let you know how it works.
  #6
Old March 14th, 2007, 12:05 PM
Doug's Avatar
Doug Doug is offline
Das Fire Führer!
Doug is a Soldier
Wonder how well the molasas 5-1 solution would work. Supposedly the acid eats the rust but leaves metal and paint alone.
Most people seem to mix it in a bucket and soak the parts for a couple days...may want to dry out and make a mess on a flat surface?
  #7
Old March 14th, 2007, 06:39 PM
poolmike poolmike is offline
Private 1st Class
poolmike is a Soldier
Remove the loose stuff...wire brush or whatever. Spray it with phosphuric acid, available at any hardware store for ~$10/gal. Then treat it to what ever finish you like. POR-15 is great stuff, but for floors and stuff, I prefer rustoleum primer then some Herculiner.
fuel tank rust removal chemistry jpsnblood Open Discussion 38 June 26th, 2011 06:26 PM
rust eater phoenix Open Discussion 2 November 28th, 2009 12:20 AM
Chasing rust again Angry_Truck Open Discussion 9 August 23rd, 2009 07:20 AM
Floor rust gargemel_622 Open Discussion 8 January 7th, 2009 08:30 PM
Rust Removal: Steps to stock preservation MarknessMonster Stock Tech 11 May 9th, 2008 05:06 PM
