I need to replace my valve seals. I have in the past done this on other engines by pressurizing the cylinder with air pressure (so I won't drop the valve) and removing the rockers, springs and replacing the seals, then adjusting the clearance. Has anyone here done this on a 230 tornado with any luck? I hate to tear down the engine for an easy fix.
The valves springs look like they might be a hassle to compress. Can anyone recommend a good valve spring tool that doesn't take up alot of room while compressing the springs?
You help would be appreciated. Dave in NM
