Results 1 to 10 of 15
Thread: Knuckle cavities
    Jan 2007
    Winona, MN.
    Default Knuckle cavities
    I'm doing some front end work. What do I fill the knuckle cavities with? I believe I removed the OEM grease. Thanks.-TB
    The manual says to use grease....like wheel bearing grease...pump it in with a grease gun till its full to the fill plug.
    Others use gear oil like civvy trucks use....
    Others mix 50/50 gear oil and grease and make what is called "knuckle pudding".
    Personally, I use grease.
    Bucket-o-grease here.
    Geneva, FL
    Blog Entries
    1
    JD CornHead grease!!!
    Washington State
    I used Lucas Red grease.
    Jan 2007
    Winona, MN.
    Are these greases of a viscosity that allows them to flow somewhat?
    Once they get warm to hot...yes. The corhead grease is more akin to the knuckle pudding idea...so it should flow easier.
    Jan 2007
    Winona, MN.
    So where do you get that stuff?
    The JD stads for John Deere....see one of their dealers...
    Geneva, FL
    Blog Entries
    1
    PART#: AN102562
  1. Front Knuckle Seals
    By fng in forum Stock Tech
    Last Post: November 28th, 2007, 12:37 PM
  2. More knuckle cavity stuff
    By terryb in forum Stock Tech
    Last Post: March 22nd, 2007, 01:52 PM
