Results 1 to 10 of 16
Thread: Fuel filler neck cracked
    Default Fuel filler neck cracked
    I am looking for the plastic? , rubber? from the fuel filler neck to the tank on a '67 m715, does anyone have any idea where to get one? If they are not available can the rubber sleeves for joining PCV pipe with a mismatch be used with gasoline? Any advise would be greatly appreciated.
    Is it leaking fuel? It's common for the fuel filler neck to develop cracks. However, these don't usually cause a problem. Unless yours is leaking fuel or you are working on a total restoration I wouldn't really worry about it.
    However, if you do want to replace it, try Memphis Equipment. They might still have one around. They are getting hard to come by.
    I checked into having a manufacturing company here build one from aluminum to match the rubber one. They told me they can do it but it would have relief cuts that they would weld up in order to make the turn and diameter reduction so as not to have to change anything up. They wanted $180 to build it which seemed high until you figure what it would cost to replace the rubber several times. Might have them make one up when I get out of the hole from the rest of the truck.
    AB lynn
    I do not believe that the rubber pipe connectors for PVC pipe will work. I think the rubber will not hold up to the gasoline. It would be worth checking with the manufacture though to see if gasoline could be run through it, but if my memory servse me (which it doesn't sometimes) they are not usable for fuel of any kind.
    Zone holster maker
    If you use rubber, gasoline will ruin it...you MUST use Neoprene with gasoline.
    Last March, AB Linn had 1 left and it had a cut on it from somebody using a knife to open the shipping box. He sold that one. This is one of those parts like defrostor ducts, cab corner moldings and a few other selected parts that the NOS supply is rapidly decreasing and once they are gone, they will be gone.
    If you make or have fabricated a workable alternative, please post pictures and a cost break down.
    Escondido, CA
    I bookmarked this from the old site. Or the temporary site - don't remember. Regardless: http://oshkoshequipment.com/details....uctID=12&pid=8
    Jan 2007
    west central wisconsin
    There was one on Ebay a while ago,I posted the details on the old board. I bougt one on Ebay before that,Memphis Equip. ,I think.
    Default filler neck crack
    Thanks for the information, I'll try Mem. Equip first and go from there.
  1. Stock Fuel Filler hose
    By xownzux in forum Stock Tech
    Last Post: September 6th, 2011, 06:27 AM
  2. Fuel filler unit
    By Chumley in forum Stock Tech
    Last Post: May 21st, 2009, 05:02 PM
  3. Fuel tank rubber filler elbow
    By Chop Parlor in forum Stock Tech
    Last Post: October 18th, 2008, 01:47 AM
  4. Fuel filler neck
    By Kamikaze12volts in forum Open Discussion
    Last Post: March 27th, 2008, 09:32 PM
  5. fuel filler hose
    By george walker in forum Open Discussion
    Last Post: July 24th, 2007, 09:15 PM
