Results 1 to 9 of 9
Thread: Buford's Back, Finally.
    Washington State
    Default Buford's Back, Finally.
    After a long haul figuring out my clutch stuff I finally have it installed and the drivetrain complete, well almost. I just need to finish my hydraulic clutch stuff, and finish brake lines. I may do a near factory breather system for the axle and t case venting them up under the dash somewhere.
    A shot of Buford Buick 350 installed and my finally installed, custom bent t case shifter, rods.
    I had a lot of bending to make the stock t case shifter rods work like they should, I think it came out great, everything works like new with the newly rebuilt 202.
    A shot of the factory stub shaft I had shortened to keep my stock driveshafts. I think we took about 2" from the stub shaft.
    A couple sideshots that show the shifters, e brake lever and the stock shafts for t case shifter bent in the shapes. Coated the joints and moving areas with sliplate, graphite base paint.
    Hopefully the pictures turn out Ok, and I didn't duplicate any. Now on the Hydraulic clutch mounting of the slave cylinder this weekend.
    Sharp! It looks really, really good.
    Port Orchard, Wash.
    Holy cow, man! That's sure come a looooong way! Looks great!
    -- Tim Taylor
    I like your t-case shifter setup Todd. Nice job!
    Washington State
    Thanks Fellas, and also thanks Dan Saxon for your help figuring out my clutch setup. Hope Arizona is nice and warm. Fisherman
    That is sweet. I dig it.
    I'd vent those lines along the firewall unless you like sucking gear oil fumes.
    Washington State
    Good idea Tacoma, I guess I didn't figure I would smell gear oil smell from the vent lines. I won't chance it now you bring it up, Good point. Somewhere along the firewall it will go.
    I wouldn't have thought so either, but I actually had to run a vent off the t-case into the cab once, and I did not enjoy it. Part of an emergency shift tower repair in BFE, 60mi drive home like that.
    Washington State
    I'll be routing those lines soon, at least getting up near the engine, then I can finish when the cab goes back on. I worked on mocking up my hydraulic clutch mounting. Pretty much done, just need to re measure and look at everthing, a little welding and bolt it up. Novak sent me two pieces for mounting, neither of which will work, but one cut apart and the second one added with some fab makes quick work of a Novak oversight. I will be able to start on my brake lines this weekend. And if I can score the winch driveshafts and shifter I will get my winch setup going.
  1. Finally Driving!
    By kyken in forum Open Discussion
    Last Post: October 20th, 2009, 12:36 PM
  2. finally turned fire truck back into an army truck
    By stranman in forum Open Discussion
    Last Post: July 8th, 2008, 07:57 PM
  3. Finally on the trail again!
    By YEromvek in forum Modified Tech
    Last Post: February 21st, 2008, 09:55 PM
