Results 1 to 10 of 17
Thread: Need some axle info
    Mar 2004
    northern Arizona
    Default Need some axle info
    Ok, for you brain-trust guys - who has the measurements on our axles? I have a chance to acquire a Dana 70 from a 77 F350 with a 4.10 ratio and a limited slip.
    Here are the measurements from the seller - question is will this fit without major mods?
    8 lug axle too.
    For the measurements I came up with about 51 between the backing
    plates and about 41 on center for the spring perches. Those measurements
    are with a slight bend in the tape over the pumpkin so not exact, but
    ballpark. The overall length is about 72 inches.
    I don't have the measurements, but that is a very narrow axle...
    I happen to have a stock D70 in the shop..will have measures for you in a little while.
    We'll have to see what Jon comes up with, but I think that is to narrow too.
    Stock dana 70 is 56.5" (me on my back under the truck with a tape) from inside of backing plate to inside of backing plate. So that axle sounds to be very narrow if the measurement is accurate. I have a dana 70 in the back of my truck that I am putting disc brakes on and measured it and got a healthy 58". I can't find a page to decipher the BOM on this axle so if anyone has a dana book here it is 3 25 6 c6 BOM 603556 2
    Mar 2004
    northern Arizona
    I just asked the guy to verify end-to-end measurements - 72 sounds pretty narrow to me as well, especially on a 1-ton truck.
    Sorry for the delay....small crisis ends...
    Inside of backing plate to inside of backing plate: 55½ inches.
    Center of spring pad to center of spring pad: 50½ inches.
    In case it matters...
    Wheel mounting surface to wheel mounting surface: 72½ inches.
    That measurements sound right for a dual wheeled truck. They tend to be a little narrow. Also Ford trucks of the early to mid 70's seam to be narrower the chevy or dodge truck. Thats just my observation.
    Tom
    Northwest Montana
    How much work would it be to put in a pair of Dodge D70 axles?
    I memory serves me correctly, the D70 from a Dodge motorhome fits the spring mounts and is in the right pace at the wheel well. I believe they are originally setup for duallys....
  1. Axle info ?
    By Whitetrashmudder in forum Stock Tech
    Last Post: December 29th, 2009, 11:48 PM
  2. bigmech : Help on axle info. ----Please !!!!!
    Last Post: December 15th, 2009, 09:02 PM
  3. saxon : info on spring over on stock axle
    By saxon in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 01:20 AM
  4. info I need to know before ordering axle gears
    Last Post: November 9th, 2008, 08:26 AM
  5. Axle info
    By jdfrmnt in forum Modified Tech
    Last Post: January 29th, 2008, 10:14 PM
