Pulled off my rear brakes to install new backing plates with the Ford wheel cylinders, loaded with new brake shoes. Thanks Dan, I'll be installing new bearing seal, packing and checking the bearings. Will replace bearings if need be. Should I turn the drums? They are not blued and appear to have never been overheated. The current shoes are about 80 to 90 % and the current stock wheel cylinders look moist, not leaking. I am going to clean up the drums and paint, should I turn them before installing or not worry about. Let me know your ideas. Thanks Fisherman
