Results 1 to 5 of 5
Thread: PS Gear/pump for 230 - price/years
    New Jersey by Philadelphia
    Default PS Gear/pump for 230 - price/years
    I found a Jeep J10 4WD pickup from the early-mid 1970's in a local yard with power steering. They want $30 for the steering box and $30 for the pump. I am not sure of the year J10, but the engine was that AMC metallic blue from the early 1970's. The year was worn off on the door jamb, but it listed tires as H78-15, so that probably was an early 1970's J10.
    My questions are: Will this box fit my 68 M715? There were four bolts into the steering box from what I saw. Do you think $60 is a fair price for the steering box, pitman arm, pump and hoses (the pressure hose was newer).
    I didnt see any leaks from the steering gear...
    You can bolt that box and pitman arm right up to your truck with the three bolt holes currently on your frame to hold the manual box on. Or, you can mark, drill out, sleeve and then use the 4th hole also.
    The setup you described is what you need.
    Port Orchard, Wash.
    My local U-Pull-It yard wants $200 for the same setup, but I could have sworn I saw a crack pipe in the guy's hand....
    I'd say $60 is not at all out of line, especially if the pitman arm is included.
    And check out the couple of threads that discuss how Todd (fisherman) and Bob Cowan have used the 4th bolt by the method Barrman mentioned. Good pics and all....
    -- Tim Taylor
    With the steering box, pump, hoses, pittman arm and the entire column out of the same vehicle....local yard here wants $125...$60 for that stuff is reasonable...
    Huntingtown,Md.
    $60, is what I paid p/s pump, box(4hole) pitman arm, and flex coupling. Everything bolted right up. Had to replace the pump, but that's all.
  1. oil pump gear
    By glockrock in forum Stock Tech
    Last Post: March 1st, 2010, 07:10 AM
  2. 230 oil pump drive gear
    By Bill in forum Stock Tech
    Last Post: March 22nd, 2009, 06:58 PM
  3. Oil Pump Gear
    By rboltz in forum Stock Tech
    Last Post: February 13th, 2009, 10:06 AM
  4. 3 years, Exactly!
    By Barrman in forum Modified Tech
    Last Post: April 7th, 2008, 11:24 AM
