ForumsOnline Maintenance ManualsGalleriesThe M715 Zone Vin RegistryVintage Power Wagons Price ListLinks
Prev Previous Post   Next Post Next
Old January 24th, 2007, 05:35 PM
stanman stanman is offline
Basic Trainee
stanman is a Soldier
Default 230 freez plug removal
This has been driving me INSANE! I decided to put in a freeze plug block heater because at my Naper it was like $2 cheaper than one that goes in the bottom hose. So I tried to remove it by hitting it on the lip. That didn't work so I tried hitting it in the dished part and poked a hole in the plug. So a good friend of mine came over with a puller for a timing chain and used one of the things on the side
and used the lip on that and some chain to try and pull it out that way because everything else didn't work. After about three to four HARD yanks, it didn't even budge a smidgen!
So my question is has anyone ever had this much trouble removing a freeze plug out of this shinning example of fine American engineering?
P.S. This has taken place over a couple of days and sprayed it with alot of Deep Creep.
spark plug removal 14fan Open Discussion 4 November 3rd, 2009 08:42 PM
cam removal kevbo Stock Tech 6 September 14th, 2009 04:12 PM
spark plug gap 14fan Stock Tech 2 March 17th, 2009 07:44 AM
Bellhousing Plug Pineyguy Open Discussion 12 January 15th, 2008 08:20 AM
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1998 - 2010
This web site is subject to the protection of the copyright laws of the United States and other countries.
Except for Personal Use Only, you may not modify, copy, distribute, transmit, display, perform, reproduce,
publish, license, create derivative works from, transfer, or sell any information obtained from any part of the
M715 Zone website without the prior written permission of M715 Zone, LLC.
Written permission can only be obtained by contacting brute4c@m715zone.com
Copyright 1998-2009
