Results 1 to 4 of 4
Thread: 230 engine backfired, now wont run
    Jan 2007
    St. Clair Shores, Michigan
    Question 230 engine backfired, now wont run
    My 69 m715 recently got new rockerarms, timing chain,timing gear, camshaft, new head gasket... and a complete valve job.... Since then it has been running fine for a month.... now it wont start, the engine cranks but it wont stay going...we can see and smell the gas getting to the carb.... the engine started fine after this then died out and wouldnt stay running unless i kept moving the throttle. eventually it backfired really loud and we havnt been able to get it running since.... We pulled the valve cover off ...everything looks fine... took the carb off and inspected it...everything looks fine.. looked at the distributer everything is fine... the firing order is right, the cables are new..... Does anyone know what could be wrong... Im thinking the timing chain might have slipped but this seems unlikey???? I just dont understand what would cause it to stop running after a month?...............any ideas??????????
    Did you set the timing properly? Mine had a similar problem.
    Jan 2007
    It was orginially set right and the thing started right up, but we havnt checked recently, we are gonna look at that tomarrow
    St. Louis, Mo.
    Sounds like its loadin up. My 02. Check the carb.Carbon is a big issue for some reason on theses motors,check the plugs for chat.
  1. Another Problem, Wont Start
    By chrisnwmsu in forum Stock Tech
    Last Post: October 5th, 2009, 02:19 PM
  2. I need a engine
    By TennesseeJeepster in forum Stock Tech
    Last Post: May 21st, 2009, 08:08 PM
  3. 725 wont start
    By Docthrush in forum Stock Tech
    Last Post: July 24th, 2008, 04:29 PM
  4. Max Engine RPM
    Last Post: June 24th, 2008, 05:03 PM
