ForumsOnline Maintenance ManualsGalleriesThe M715 Zone Vin RegistryVintage Power Wagons Price ListLinks
Prev Previous Post   Next Post Next
Old January 7th, 2007, 06:55 PM
Elohim1 Elohim1 is offline
Elohim1 is a Soldier
Default Th400/torque convertor install ??
I was looking into some tranny fluids and found that you are supposed to put at least 1 quart of oil in a torque convertor before you install on tranny. Well, I didnt do that and the tranny is installed. I called a tranny shop and the fellow said he has installed convertors without oil sometimes. He said to fill tranny up ,of course, and start pouring fluid in when he motor starts because the torque convertor will suck the fluid out and burn the pump up. I guess the TH400 holds 11-12 quarts.
My torque convertor is new and I dont think there is a drain plug on it where I could fill. Tranny is newly rebuilt also.
My question is , should I drop the tranny and fill the convertor or just add fluid as it starts?
AMC 360/TH400/QT swap compexp Modified Tech 7 March 15th, 2010 10:37 PM
torque spec? green goat Open Discussion 2 June 16th, 2009 01:29 PM
Th400/np208 Tomahawk715 Modified Tech 4 January 21st, 2009 06:54 AM
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1998 - 2010
This web site is subject to the protection of the copyright laws of the United States and other countries.
Except for Personal Use Only, you may not modify, copy, distribute, transmit, display, perform, reproduce,
publish, license, create derivative works from, transfer, or sell any information obtained from any part of the
M715 Zone website without the prior written permission of M715 Zone, LLC.
Written permission can only be obtained by contacting brute4c@m715zone.com
Copyright 1998-2009
