Anyone know what the civilian tire size equivalent of the military 9.00x16 tire is? What is standard 9.00x16 NDT tire diameter? Thanks,
The formula for tire size is:
(tread width x aspect ratio) x 2 + wheel diameter = tire diameter
All crossply tires (such as 9.00x16) have a 100% aspect ratio.
So (9.00" x 1.00) * 2 + 16" = 34" diameter
An 11.00 x 16 would be (11" * 1.00) * 2 + 16 = 38" diameter
A (325/75R16) would be 325 mm tread width, 75% aspect ratio and a 16" diameter. There are 25.4 mm per inch. So (325/25.4*0.75)*2 + 16 = 35.2" diameter. However, actual diameters are typically less than what is calculated.
You can take it from here.
Great info, thanks!
A 315/85R/16 is real close...
