ForumsOnline Maintenance ManualsGalleriesThe M715 Zone Vin RegistryVintage Power Wagons Price ListLinks
Prev Previous Post   Next Post Next
Old January 1st, 2007, 11:44 PM
spr-m715 spr-m715 is offline
Civilian
spr-m715 is a Soldier
Default Steering shaft question?
I have mounted my steering column. It is a 2004 Super Duty Column. I want to keep the ford factory cruise and turn signals and it has the Ford Factory Pats system with electronic key a little added security. The question is... I can not find a steering joint like the super duty column has. Its like a double d but flat on one side. I have a steering box out of a cherokee so that joint is not a problem. Does anyone have a place to get ford joints made up or seen them anywhere?
has anyone rebuilt the steering shaft ujoint? Duane Stock Tech 5 March 21st, 2010 06:50 PM
gimpyrobb : Steering shaft bushing ? gimpyrobb PseudoZone - Open Archive 4 November 10th, 2009 09:31 PM
Steering shaft size. BulletSponge Modified Tech 6 April 23rd, 2009 09:03 AM
u-joint steering shaft. alosix Modified Tech 5 June 22nd, 2007 12:41 PM
Steering shaft u-joint type anyone use? tngreenmachine Modified Tech 1 March 16th, 2007 11:48 AM
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
1998 - 2010
This web site is subject to the protection of the copyright laws of the United States and other countries.
Except for Personal Use Only, you may not modify, copy, distribute, transmit, display, perform, reproduce,
publish, license, create derivative works from, transfer, or sell any information obtained from any part of the
M715 Zone website without the prior written permission of M715 Zone, LLC.
Written permission can only be obtained by contacting brute4c@m715zone.com
Copyright 1998-2009
