Can I put a larger crankshaft pulley on a 230? Like, bolt one on?
My truck won't charge at idle unless I give it a little choke, and I'd like to turn the alternator (retrofit GM one-wire) a little faster. The pulley on it seems to be as small as can be fitted, so I guess the only alternative is to upsize the crankshaft pulley. The idle speed is already set a little high, by the way (I don't have an RPM for it).
The guy I built the truck with has an M37 with an IH 240-6 in it, and that thing has a crankshaft pulley the size of a pie pan. He has no low-speed charging issues.
