The only figure 06-19 that I have is an internal shot of the alternator with only 3 parts numbered....
I am guessing you mean that you have the rubber type connectors attached to the bulb and the metal ones on the truck.
If that is correct, then you need a short piece of wire that has the other half of the military connector on one side and the rubber type on its other end...that is what should be there...I dont see a reference in the parts manual....
