Results 1 to 10 of 12
Thread: Tire diam.
    Default Tire diam.
    While at randy's ring and pinion site I used the rpm calc they have on there.
    Whould it be better to park the truck on concrete and measure from the center of the hub down and double it for the tire size? It just seems tires are smaller than labeled.
    Its very common for tires to be listed at a certain size but really be shorter...many 38's run 36.8 to 37.5 inches tall...some even run less than the 36.8 height...
    Dont ask me how they get away with that...
    Lake Hopatcong, NJ
    Yes, it would be more accurate to use two times the static loaded radius as your tire diameter in rpm/gear ratio calculations. Make sure the tires are inflated to the pressure that you plan to run them.
    Rim width etc has an effect on the height... but yeah, Interco in particular is known for running short.
    Boondockster, good post-- that is excellent advice.
    Yeah, Interco sucks. Poor quality, poor design and horribly over priced for what you get.
    Easy now. Their designs work. I'll get some 47" LTB's sometime I think. Stickier than Michelins, and those stupid-ass Claws too.
    West-central Ohio
    Quote Originally Posted by tacoma View Post
    Yes, boondocker is spot on. Tire growth at speed is something folks not in the realm of M715s should consider, but we're pretty much immune from that.
    most things that operate at highway speeds are, I'd say.
    Lake Hopatcong, NJ
    Funny you mention that bump_r! I almost added a caveat for centrifugal force but realized it's not an issue for most M715's
    Either way, it is better than using the number on the sidewall.
    Lake Hopatcong, NJ
    Thanks Tacoma! I'm new here and I'll try to be a good poster.
  1. tire size ?
    By CHRIS UNGER in forum Modified Tech
    Last Post: June 15th, 2017, 10:29 PM
  2. Tire Source
    Last Post: March 14th, 2009, 05:36 PM
  3. Tire Questions
    By jlogan in forum Open Discussion
    Last Post: March 14th, 2007, 04:13 PM
  4. Tire prices?
    By SHOOTER68 in forum Open Discussion
    Last Post: March 9th, 2007, 10:53 PM
  5. M-725 spare tire
    By rpgdeity in forum Stock Tech
    Last Post: February 28th, 2007, 05:26 PM
